Ok Probably Being Stupid Re Mfd
simon bidle
how do I access the settings menu? I only have the buttons on the indicators and nothing on the steering wheel. is it possible? I've had many golfs etc but they had the buttons on the steering wheel.
I can change through the settings up and down like avg fuel/ fuel left etc, I just can't add or delete the view.. is this only possible carista or vcds?
thanks
I have the buttons on the wheel so not 100% but I think you control it using the buttons on the right stick and think you may need to hold in the end button to access the menu
If all else fails RTM
Can you adjust them through the media screen, there is a "settings" menu on mine as well as my steering wheel.
Press and hold lower button on right hand stalk. Then you can navigate the menu that appears with upper and lower buttons and select with the button on the underside of the stalk.
