Oil Pressure Regulating Valve
ben_smith1987
Does anyone have an OEM part number please for the above?
VW Van Centre are recommending replacing it, and trying to get quotes from other garages to compare, but no one can locate the part under the description above (the one given to me by VW) and without the part number/code.
Any help v.gratefully received, cheers
N428 valve . . . ? - not sure on OEM part number yet?
Removing and installing oil pressure
regulating valve - N428-
Removing
– Remove front engine support ⇒ page 40 .
– Disconnect electrical connector -1-.
– Place a cloth underneath to catch escaping engine oil.
– Unscrew bolt -2-.
– Remove oil pressure regulating valve - N428- .
– Cover open parts of engine to prevent ingress of dirt in lubrication system.
Installing
Install in reverse order of removal, observing the following:
– Renew O-ring after each removal.
– Check oil level ⇒ Maintenance ; Booklet 20.1
Removing
– Unscrew bolt -2-.
Installing
Wonderful - that’s really helpful! Thankyou
