‘Oil’ message when ignition on but no warning light
Tlc
When I start my t6 up a message comes up check oil ? I’ve done this an the oil level is fine an the message goes when I drive it should I get it to the garage
The level sensor is a common VW failure. Not see one fail on T6 but I've seen it come up on a few vehicles when scanning them. As long as you have oil in the engine, don't worry to much and take it to a garage.
Reactions: Tlc
If it was an actual oil warning (ie the level is low) then it would be a red light on the dash not a word on the display
Reactions: Tlc
