OEM Webasto Auxiliary Heater To Parking Heater Upgrade
That's the one indeed. I like the longer distant to switch it on with an APP.
So there is no possibility to swtich on the heater with just a +12V signal?
Everything is possible mate but I didn't explore it any further so can't advise.
Telestart approach was simple and inexpensive, at least in my case.
My final coding (with 1 fault caused by missing overhead timer) is 5101.
Important settings to notice are as follows.
Byte 0 bit 0 activated - prevents flattening the battery
Byte 0 bit 2 deactivated - allows to heat engine and cabin simultaneously
Byte 0 bit 3 deactivated - front fan is controlled via CAN (for Cimatronic unit)
Byte 0 bit 4 activated & bit 5 deactivated - enables remote control via Telestart
Hi Robert, first of all many thanks for the great summary you've shared here!
I carefully read all your way towards this result. I have T6 Multivan MY2019 with pre-installed OEM Webasto.
Just ordered three components needed:
- 3Q0 963 513 - Telestart OEM form VAG
- 3G0 963 511 B - Remote to pair with the above
- the loom set with aerial for wiring the Telestart module under the front right seat.
Unfortunately, I don't have VCP, but found some chaps around to help me with re-flashing.
For adaptation Adapter 18, I have Carport that luckily do the change form 4101 to 5001 (or 5101 as in your last post). Just checked it.
The question is about overhead panel.
I don't have one in my T6. Today I checked that under the cover, there is no any wire to plug for the VAG 7E5 919 037 J (the latest panel version), that I can easily get on eBay.
Did you managed to get through this?
As I can see, the fault code you still have is exactly due to the absence of the overhead timer.
The overhead location is quite tight but I feel there should be the way to get the panel connected to the power and CAN-bus without entire roof cover removal.
Thanks for sharing thoughts!
I don't need timer so I purposely didn't install overhead unit. Remote only works 100% for my needs.
Installation of this overhead unit is very simple, just power supply and CAN wiring which can be ran through A pillar and there is no need to remove roof lining at all :thumbsup:
See wiring below (4th picture).
Hi Robert, yes, this is exactly how I plan to do this.
It seems to me that both CAN links can be soldered directly to BCM T73b socket while +12DC and GND can be sourced somewhere nearby. I assumed that blue socket T10af in left A-pillar fuse/socket box doesn't exist in my case. (My T6 is LHD and therefore the BCM is on the left side)
Once panel is installed and properly connected, do I need any specific adaptation for it?
Many thanks again!
I will write the separate post once I'm done with this.
Many thanks again!
You just need to add your new unit in CAN Gateway(19) INSTALLATION LIST and then verify its own coding but default coding should work anyway.
Hi everyone, does anybody know if for T5.1 is the same wiring procedure? I own a T5.1 2011 without parking heater, only stationary. I intend to install the overhead module and to operate it by there.
Thanks in advance
Hi everyone, does anybody know if for T5.1 is the same wirring procedure? I own a T5.1 2011 wihout parking heate, only stationary. I intend to install the overhead module and to operate it by there.
Thanks in advance
Can you post your complete VCDS autoscan?
Can post your complete VCDS autoscan?
Yap Robert, it is a Thermo Top C, and Climatic AC, not Climatronic
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AC HW: 7E5 907 047 AC
Component: Climatic-T5 H11 0203
Revision: 00001005
Coding: 0000000002
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 70EF65C7ABA31ACF55-8024
No fault code found.
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 24475997E7DBF66FE1-8070
Revision: 00001005
Coding: 0000000002
Coding: 0000031
Thanks for this but can you post your complete VCDS autoscan? I would like to see all components on board of your vehicle.
Here you go
Code:
Saturday,21,November,2020,15:35:59:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZBH131677   License Plate:
Mileage: 291860km-181353mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 18 19 25 37 56 69 77 0B
VIN: WV2ZZZ7HZBH131677   Mileage: 291860km-181353miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JF    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H35 9108
   Revision: 22H35---    Serial number: 00000000000000
   Coding: 0119401A233400080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20BTD01103L906022JF 002011
   ROD: EV_ECM20BTD01103L906022JB.rod
   VCID: 72EB6FCFA5AF28DFA3-8026
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 208764AD09A7049626A890786A6510
   Shop #: WSC 02756 790 49152
   VCID: 366393DF814774FF4F-8062
   Revision: 00001005
   Coding: 0000000002
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 104110043
   Coding: A0B0793A0E212012002808107C2B8DD50080410F60844000300000000000
   Shop #: WSC 73430 790 00001
   VCID: 377D9EDB864D8DF754-8062
   Subsystem 1 - Part No SW: 7E0 959 801 A    HW: 7E0 959 801 A  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Serial number: --------------------
   Coding: 040000
   Subsystem 2 - Part No SW: 7E0 959 802 A    HW: 7E0 959 802 A  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H06 0022
   Serial number: 40000000000000322322
   Coding: E20000
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H06 0013
   Revision: --------    Serial number: 003HL005615F
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02754 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 356194D394417FE746-8060
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 870 C    HW: 7E0 920 870 C
   Component: KOMBI         H20 0220
   Coding: 160F00
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 295948A348F92B07D2-807C
   Coding: 0000031
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042200
   VCID: 70EF65C7A3A31ACF55-8024
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 291865 km
                    Time Indication: 0
                    Date: 2015.04.14
                    Time: 15:26:38
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0220
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB77AF8D7FE01F1B-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 7F0 035 680     HW: 7F0 035 680
   Component: RNS-MID       H42 2726
   Revision: AB001001    Serial number: VWZ6Z7L6082062
   Coding: 04000402040000A000
   Shop #: WSC 02754 790 00000
   VCID: 63C51A8B6255B157D8-8036
Address 56: Radio        Labels: 1T0-035-680.clb
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000145412058
   Coding: 410D000100000000
   Shop #: WSC 02756 790 00000
   VCID: 306FA5C763235ACF15-8064
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603139206
   Coding: 020101000100000000000000
   Shop #: WSC 52753 001 1048576
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
End-------------------------(Elapsed Time: 02:49)--------------------------
Thanks in advance
Below an extract from a MY13 Transporter, which is similar to yours but with OEM overhead control panel and OEM remote. The part number of Webasto is different than yours, which leads me to believe it wouldn't be straight fit. I don't know if you could reflash yours to be the same.
Address 18: Aux. Heat Labels: None​
Part No: 7E0 819 008 D​
Component: J737__Standheizung 0605​
Revision: 00084000 Serial number: 09019169F00000​
Coding: 0001322​
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb​
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G​
Component: Dachdisplay H15 0185​
Revision: 10100011 Serial number: 259065​
Coding: 000203​
However, here is a scan of a MY13 Amarok having the same Webasto as yours and this has an aftermarket control panel (an oval shaped Webasto) and a remote - so obviously doable. Even the "serial number" is the same.
Part No: 7E0 815 071 B​
Revision: 00085000 Serial number: 09019275F00000​
Coding: 0030031​
Coding: 0001322​
Coding: 000203​
Coding: 0030031​
I am also looking how to wire the overhead control panel. And maybe, after that, i can code with vcds the overhead control panel and the webasto unit with other version of flash. I think, the webasto is fizically the same. Only different software version.
Do you know where it is the overhead control panel wired? CAN i think .....but where exactly can be found?
It's the unit J702 in chapter 63 >here<. Just convenience CAN bus and power. Depending on your vehicle the bus can be found e.g. next to the heater, connector T8aj (probably page 89/3 for your van).
Let us know how it goes.
PS.
PS.
I do not know why, i do not have access to the link from your post. I am banned to that site.
