Hi All,
I recently wired an aftermarket stereo and power amp (nothing huge) to the OEM leisure battery, in the case of the stereo to stop it power cycling on stop-start. The devices all work fine but the battery doesn't seem to be charging, I'm pretty sure all the wiring has gone back correctly but before pulling it all out again I wanted to check if there are any other checks to carry-out. For example:
- Does the alternator only charge the leisure battery once the main battery is fully charged? This could be an issue with shorter trips.
- My airbag warning light is on (because I switched the ignition without the seat cables connected) presumably this won't have an impact?
- There's an 80 Amp fuse under the passenger seat that the charging cable connects to which is intact, do I need to check other fuses?
