Nut-washer Tool?
Grim Reaper
VCDS User
Is there a specific tool to remove these things?
I'm sick of slicing my fingers open when trying to remove them manually, can't always get a pair of needlenose pliers in to do it either.
Paynewright
Bit of wood with two carefully spaced nails? Perhaps a drilled hole to go over the stud?
What are they ? Heat shield fixings?
Ian
Grim Reaper
VCDS User
They are used in various places to hold heat shields and plastic underbody protection parts in place.
czmate1999
I'll be the first then...
I have been looking for a good nut washing tool for ages - never one of my other half's strong points... :smile bounce:
Ads_Essex
Local lowlife
Moderator
T6 Legend
Long nosed pliers. They’re a bugger when the screw is rusted - just prise the centre out with the pliers and it’ll unscrew. Wear gloves when unscrewing as they ruin the tips of your fingers :mad:
Daffy
I used long nosed pliers too
