We've just bought a T6 that's in the queue to be converted to a pretty standard full-conversion. I'll be wanting to add solar at some point, but it's stretching the budget a little far right now. Will be using a compressor fridge, charging phones, night heater and internal LEDs. From what I've read, a 200w system should handle that. So is this something that's easy enough to add at a later date, or should I be sorting it all now at the point of conversion? Is there any pre-emptive wiring I should ask them to do at the point of conversion (LB's under driver seat, electrics in rear cupboard)?
If we want to start with just a portable system (with its own regulator), can this just connect directly to the leisure battery? If we then want to add a panel to the roof (pop-top), what's needed to get this wired so that it keeps both the leisure battery and the starter battery topped up when we're not using it much in the winter (is there some kind of fancy regulator/controller to manage all this)?
...I have done a bit of searching on this, but all the options are currenlty making my head explode!
