Most Comfortable Suspension
773687038
Hi guys!!! Had my 24 plate t28 for about a month now I’m absolutely in love having come from a tranny it’s like night and day. She’s got 16s on all standard but I’d like to get some bigger wheels on her however i love the comfort of the ride now.
I was thinking 19s or 20s and about a 50mm drop
Can someone please tell me the most soft and comfy set up regarding suspension and wheels and tyres that’s going to feel as close to the OEM set up as possible.
I just seem to be going round in circles trying to figure out a route to go down.
You guys have a lot of knowledge so il trust your opinion.
Cheers guys!!! 7
Comfort is subjective to taste. Some of the contributors to this fine forum are suspension specialists and can advise properly with respect to your tastes, needs, and use.
I actually don't find the ride too bad either, albeit mine has 360kgs of camper conversion permanently aboard to dampen some of the movement.
To acquire the best ride then stay at the same height but use better damping or spring damper setup. KONI would be my choice. 18" or 17" inch voluminous tyres also can help with requiring lowered tyre pressures. If the vehicle is dropped then that makes the task more difficult to achieve and thin elastic band tyres as required by very large rims does not help with ride or comfort either.
Cheers guys!!! 7
With needs like that , we are probably the best company to call , Most Transporter specialists will try and sell you a Coil over kit , This wouldn't be the best set up for max comfort , give us a call and we will explain nicely what to do .
