Mib2 retrofit & VDS errors to solve
xmetralla
Hello Mrs.,
I have a problem since installing a Discover Media (ref. 5C0 035 680 C) on my T6 Westfalia Kepler One (basic Transporter chassis). CP is off & I buyed it from Poland Ebay. I had to change the USB connector for the carplay to work, and it works properly. All the functions OK. Now I am waiting for the DAB and GPS antennas. VCDS currently has several errors:
1- Error in module 5F - GPS antenna (normal, it will be fixed soon).
2- Error in module 5F - DAB antenna (normal, it will be fixed soon).
3- Error in module 5F - component protection activated (normal as it is a non-standard equipment, I don't know if it can be fixed).
4- Error in module 17 - Component protection activated (normal being a non-standard equipment, I do not know if it can be fixed).
So far the mistakes are logical.
The problem is that I get an error in module 37 Navigation - unregistered, when this error with the old infotainment (composition color) did not appear. Also, it is not selected in the gateway device list. I tried to select, save, deselect it, and save again, but the error still appears. I tried to clear the error, but it still appears. I imagine the problem may have to do with the coding of the 19 CAN gateway module, but I don’t know what changes I need to make to solve it.
Would anyone know how to help me? Thank you so much.
Apologyses if you don't understand any word, I have VCDS in spanish and I've translated the scan word by word.
Sunday,23,August,2020,18:50:58:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: EST 19.6.1.0
Data Version: 20190908 DS308.0
VIN: WV1ZZZ7HZHH1***** Matrícula:
Mileage: 30005km Orden de Trabajo:
Chassis Type: 7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 5F 61
VIN: WV1ZZZ7HZHH1***** Mileage: 30005km
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-Gateway CAN -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. EST\04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014432401090000
Shop: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 010930039009034796-8054
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: EST\7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Version: 00000000 Serial Number: 40617000002244
Coding: 557E40982566847EAA77027FA48321F6780000
Shop: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8DF6FBA67DB5B7A0-806A
Address 04: Steering Angle (G085) Labels:* EST\6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial Number: 11021713471109
Coding: 01
Shop: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77CBFEB-802A
Address 08: Auto HVAC (J301) Labels:| EST\7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Version: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 72EB6FCFA5AF28DF9F-8026
Address 09: Cent. Elect. (J519) Labels:. EST\7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Version: B9081001 Serial Number: 0982 060171664
Coding: 62A8393A0A23201201200F742CEB86D48F90710F60466970320400A30800
Shop: WSC 02737 534 585128
VCID: 2A5BB7AF45FF201FE7-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: EST\5K7-955-559.CLB
Component: RLS 280217 04 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 003 0653
Serial Number: KU0KU001031770607293
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 003 0653
Serial Number: KU0KU001031770603460
Coding: 1400A0
Address 10: Park/Steer Assist (J446) Labels:| EST\7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Version: -------- Serial Number: 32931701004872
Coding: 108001
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 4385FA0BCA95D157C4-8016
Address 15: Airbags (J234) Labels:| EST\5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag020 H08 0018
Version: -------- Serial Number: 003V3003ZPES
Coding: 000000000000000000000000000000003230
Shop: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3A7B87EFBD5F909F97-806E
Address 17: Instruments (J285) Labels:| EST\5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 860 S HW: 7E0 920 860 S
Component: KOMBI H03 1104
Serial Number: 00000000000000
Coding: 150B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 387F9DE78353828F61-806C
1 Fault Detected:
15360512 - Component Protection
U1101 00 [009] - -
[Nueva función! Sólo nuestras interfaces HEX-NET y HEX-V2 dan los detalles de avería extendidos]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frecuency: 1
Reset Counter: 217
Mileage: 29837 km
Date: 2020.08.02
Time: 18:48:43
Address 19: Gateway CAN (J533) Labels:. EST\7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Version: B9081001
Coding: 042205
VCID: 68DF0DA79B73D20F31-803C
1 Fault detected:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frecuency: 1
Reset Counter: 255
Mileage: 29837 km
Indicación de Tiempo: 0
Date: 2020.08.23
Time: 18:48:53
Address 25: Immobilizer (J334) Labels:| EST\5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial Number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB77AF8D7FE01F27-803E
Address 37: Navigation
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| EST\5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H20 0253
Serial Number: VWZAZ2R0127599
Coding: 065700013C00000011111101008908001F0106C6002001000F
Shop: WSC 01357 011 00200
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2149508330C9E347B6-8074
3 Faults Found:
15360256 - Component Protection
U1101 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frecuency: 1
Reset Counter: 217
Mileage: 29837 km
Date: 2020.08.23
Time: 18:49:03
Tensión del borne 30: 12.2 V
2565 - antena GPS
B1054 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 4
Fault Frecuency: 1
Reset Counter: 217
Mileage: 29837 km
Date: 2020.08.23
Time: 18:49:03
0011 - Antena 1 de radio digital
B1103 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 6
Fault Frecuency: 1
Reset Counter: 217
Mileage: 29837 km
Date: 2020.08.23
Time: 18:49:03
Estado antena 1 de radio digital-Corriente de la antena: 0 mA
Estado antena 1 de radio digital-Conexión entre radio y amplificador de antena: eléctrico OK
Estado antena 1 de radio digital-Conexión entre amplificador de antena y antena: eléctrico OK
Estado antena 1 de radio digital-DAB_Bit_Error_Rate_FIC: 0.000000
Estado antena 1 de radio digital-DAB_Bit_Error_Rate_MSC: 0.000000
Address 61: Battery Regul. (J840) Labels:. EST\1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B7A73
Shop: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial Number: 75885700001702200044
End---------------------(Elapsed Time: 02:35)-----------------------
You unticked 37 on this screen? Engine not running, IGN ON?
1) Battery voltage high enough?
2) You could try to edit/save Gateway Installation List - IGNition off (drivers door open).
3) You could try latest VCDS version (20.4.2 English). It works nicely in parallel with Spanish one.
4) Disconnect battery for a few minutes so that Gateway gets a fresh start.
