MFSW buttons not working 2011 T5GP Help
Pat Connolly
I have bought and fitted This:
VW GOLF MK6 GTD 2009-2012 FLAT BOTTOM STEERING WHEEL with Paddles to my:
2011 vw T5GP 7speed DSG shuttle.
Fitted the 2 wires from clock spring 9 and 10
Pin 9 on clock spring to an ignition live, To pin 15 on the light switch This works the illumination on the steering wheel and comes on with the auto-lights.
Pin 10 on clock spring to pin 17 of the white 73pin plug on the body control module ,
this already has a wire in that position as its the Lin bus, Lilac and white wire I have soldered this connection.
My problem: No buttons work,
What does work: DSG paddles and horn work fine,
All the buttons illuminate,
Can anybody help solve my problem Please?
Regards
Patrick
Full Autoscan:
Monday,11,November,2019,16:50:56:39175
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZBH114478 License Plate:
Mileage: 245200km-152360mi Repair Order: 11-11-19 faults
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 4B 56 0B
VIN: WV2ZZZ7HZBH114478 Mileage: 245200km-152360miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
4B-Multifunc. Module -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC X41 9133
Revision: 26X41--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74B2D67CBE32BFD7DDF-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 J HW: 0BH 927 711 C
Component: DSG DQ500-7F H04 1407
Revision: 00H04V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VW36.rod
VCID: 3C223E5CD6E23797D5F-8068
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 208724AD09A5049924A69078AA6616
Shop #: WSC 02756 790 49152
VCID: 36362C74E84EEDC723B-8062
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AJ HW: 7E5 907 047 AJ
Component: Climatic-T5 H11 0203
Revision: 00005001
Coding: 0000000002
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 77A8E170AF44D4CFF8D-8022
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Revision: BO047001 Serial number: 0396 071110566
Coding: B8B879B86E61261383284ED07EEA9EDCF08041FF60840000300000000000
Shop #: WSC 02754 790 12345
VCID: 37282170EF4414CF38D-8062
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 100311 05 54 0403
Coding: 03302E
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Serial number: --------------------
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 050000
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
Subsystem 7 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0142037
Coding: 830000
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 245097 km
Time Indication: 0
Date: 2014.04.02
Time: 00:43:37
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 C HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0011
Revision: -------- Serial number: 47401035600423
Coding: 000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01004
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 323E106404A6F1E70F3-8066
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL004EFE2
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 35342B78F5C8E6DF2A1-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 C HW: 7E0 920 970 C
Component: KOMBI H20 0220
Coding: 160E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2A0E08042C76B927B73-807E
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial number: 09019275D00000
Coding: 0000031
Shop #: WSC 13636 131 88224
VCID: 2310E52047DC686FF45-8076
3 Faults Found:
01444 - Under-Voltage Shut-Off (Automatic)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 245097 km
Time Indication: 0
Date: 2014.04.02
Time: 00:50:48
Freeze Frame:
OFF
Temperature: 6.0°C
Voltage: 14.01 V
Temperature: 4.0°C
01414 - Combustion-Air Blower (V6)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 5
Reset counter: 255
Mileage: 245099 km
Time Indication: 0
Date: 2014.04.02
Time: 00:54:48
Freeze Frame:
Start
Temperature: 4.0°C
Voltage: 14.28 V
Temperature: 2.0°C
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 245123 km
Time Indication: 0
Date: 2014.04.02
Time: 23:14:50
Freeze Frame:
Malfunction
Temperature: 11.0°C
Voltage: 14.01 V
Temperature: 2.0°C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 040300
VCID: 70BADA6CCAAA83F7397-8024
2 Faults Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 245097 km
Time Indication: 0
Date: 2014.04.02
Time: 00:43:41
03590 - Control Module for Multifunction Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 245097 km
Time Indication: 0
Date: 2014.04.02
Time: 00:43:42
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0220
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8EC804ECF67927773-803E
Address 4B: Multifunc. Module
Cannot be reached
Address 56: Radio
Cannot be reached
End----(Elapsed Time: 02:28, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
Bump
I was hoping Loz or any of you VCDS guys might be able to take a look at my Vcds scan and help me sort my MFSW
Do you have a pic of the wheel with the airbag removed?
I seem to remember that wheels with a module in the middle like this don’t work.
Hi Deaky,
Thats the very same wheel as you can see below...the great news is:
I had a play about with VCDS tonight when I got back from my working away all week, the result is:
Both sets of buttons are working on my new Golf Mk6 flat bottom wheel.
The left hand side does change volume, station and music tracks on my Chinese head unit. the CC is still on the stalk and all still works fine.
The right hand buttons change the full menus of the MDF, this is with leaving the controls on the wiper stalk in-place.
I would like to eventually change the left hand buttons to include CC, I don’t know if this is possible yet I've read that people who have tried to do this even with changing out the left hand stalk to none CC still cant get the buttons to work….would like to hear if anyone managed to make this CC work of the MFSW button.
I have put up all the pics of the part numbers that might help others !
Patrick
button controle unit.jpg the wheel.jpgairbag connector wire locations.jpg airbag loom part number.jpg button controle unit.jpg clock spring and stalk numbers.jpg
Nice work Patrick, do you know if that’s the only part combo that works mate? Wired mine in today and haven’t even got lights. Had a guy try to code it and he kept saying his machine wouldn’t talk to port 7 (whatever that means) . I've got the same wheel going in a 2012 t5.1 kombi
Sorry unable to help on your issues! Was just wondering how hard is it to get my wheel illuminated? I have swapped my steering wheel and will be happy just to have it lit at night. Is this a simple job I could do myself?
You need a proper vag-com lead and then put a tick in the box for multi function wheel......everything works on mine, including the illumination!
