LWB Caravelle Rail Cover part/no?
sofakingwrong
Hi anyone with lwb caravelle rails able to pop a cover off the back of their Center double rail and share a part number with me please? It would be much appreciated.
The smaller covers don’t fit and unless I’m missing something front rail covers are different from back
Your right...2 outer are short 2 inners are long..
Have you got all the same at front?.
No at front I got outers two short covers with the load rings ...inners two longer covers ... getting round to getting floor fitted and packing floor up. Thought the front covers were same as back but it doesn’t appear to be the case unless I’m missing something
I can't get a part number atm pal as they are covered with doors.. will get it for you in morning once empty
:) Thanks @Fish I think I’ve got to the bottom of my problem the drawing was a huge help. I have the right clips/ covers it is down to my fitting of them and cutting of the floor. The clips sit as shown in the rail correctly and there is a length that extends out from under the clip.. I should of put floor over the top of it instead of cutting it out :cry: so looks like it’s time to start again.
