jason robinsonuk
hi all i am looking to lower my t6 t28 want to drop about 80mm but have 20" with 175/40/20's will i have any problems and any advise on coiler kits
thanks jason
thanks jason
As far as I know, STX will only go to 65mm not the 80 you require.My van has finally arrived after 16 months a T30 4 motion ,and I went and had a look at it today.
I measured the centre of the wheel to the top of the wheel arch and it is 480mm.
I don't know if it will settle a bit once driven, But I want to get it to about 400mm gap from centre of wheel to top of arch. Have many had to drop 80mm. I was going to get the Koni off Steve at CRS but I think I will have to go with STX at that drop. Your advice please Steve. And at that drop will I need longer drop links. I am in OZ
275 40 20 tyres on the front generally touch the inner liner of the wing. Even on a 8.5 inch tyre at 70 mm we have them touching the offset will also play a part. It’s. Very difficult because every Tom dick and harry push 275 40 20. Normally because they are cheap , there are much better sizes to use. Factors. Like. Rolling diameter. Total width all affect performance and fuel economy. There is an art to getting the correct tyresyes it was a typo the tyres are 275/40/20
Speak to Steve @CRS PerformanceLooking for a set of Coilovers -80mm max its my daily so want comfort on 20s
The H&R Ride height adjustable kit is brilliant, streets better than all the other kits available is the van a T 28 T 30 or T 32 ??Looking for a set of Coilovers -80mm max its my daily so want comfort on 20s
mine is a t28 and will not be carrying any weight in the rear. Its my daily so would like it comfort if thats possible
Speak to Steve (and then get it lower than he suggests for comfort because it looks good )Speak to Steve @CRS Performance
Cake and eat it scenario. H a ha The problem is with super light rear ends its a battle to get as low as you want to on the adjustersmine is a t28 and will not be carrying any weight in the rear. Its my daily so would like it comfort if thats possible
