Just to move this out of the other deadlocking thread as it has branched out from the "do I have it" to "its not working as it should".
I have been doing some comparisons between mine and @DaveyB's as his works as I expect it to and mine doesn't.
The main problem with mine is the B pillar button which is documented to only disable the Volumetric sensors and the anti-tow sensor is also disabling the deadlocks which is undesirable when camping.
The test for this is as follows;
(the test for this, is to leave the drivers window down and lean in and pull the handle a couple of times to see if it open the door.)
1. lock vehicle without operating the B pillar button (not lit up) (only lights up and can only be operated with drivers door open) with a single press of the remote. RESULT: a double clunk of the locks. and its deadlocked.
2. unlock, lean in and press the B pillar button and it will light up. Close and press the lock remote once. RESULT you should hear the same double clunk. if you only only hear 1 then it's not deadlocked.
Please note that pressing the lock remote a second time will turn off deadlocks and this is normal.
