Evening all,
After some help with a electrical issue with lights.
This evening i have come out to the van and seen that the rear left driving lights didn’t come on when I unlocked the van, abit of quick checking this is the current working and not working status
Rear left light
Reverse light - working
Indicator - working
Brake light - working
Driving lights - not working
Rear right light
All working
Front left light
Main/dipped - working
DRL - working
Indicators - working
Side light - not working
Front right light
All working
I have checked the fuses for rear lights as per the picture and the fuse is fine (swapped with 12v socket fuse and is working when swapped)
I have had a bulb warning light on the dash since I have fitted the vanstyle DRL LED strip kit in bumper (5 position relay has been fitted but not functioning as vanstyle says it should!) so I have no idea if the fault has appeared since or as a consecune of fitting the kit..
Any help on this would be gratefully received!
Thanks,
Rear left light
Indicator - working
Rear right light
All working
Front left light
DRL - working
Front right light
All working
Thanks,
