Leisure Battery
Discussion in 'General VW T6 Chat' started by DPDP, 14 Jul 2019 at 14:00.
  1. DPDP
    DPDP Member
    Map
    Looking to connect an extra battery....in-line so I have longer time before I have to get battery charged while wild camping. See attached pics this is the one in the van at the moment but dont recognise the brand....any ideas? I the 85 AH version. Is it correct I have to have the same brand and power to connect them in-line?
  2. Deaky
    Deaky On yer bike VCDS User Moderator VIP Member T6 Legend
    Map
    It is recommended that both batteries are the same type, age and capacity
  3. DPDP
    DPDP Member
    Map
    Thanks Deaky.
  4. Bobbych
    Bobbych New Member
    I'm no Battery expert but I can do a good Google Search, An image search of that battery returned no results. I would question the quality of the battery. Adding a different battery to this one will probably give a poor performance. As Deaky says both batteries should be the same type and capacity to get the best performance. or just go for 1 higher capacity battery.
  5. DPDP
    DPDP Member
    Map
    Thanks Bobbych for your help I couldn't find it either. Will probably go down the route of a larger battery.
  6. PlanB
    PlanB New Member
    I have seen many a wild camper lugging a 70ah leisure battery up the mountain to keep the fridge & heater going all night.
  7. DPDP
    DPDP Member
    Map
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
