Anyone recommend a good quality AGM? eBay seems flooded with them ranging from £60 - £200.
(Not ready for lithium yet).
Another thumbs up for Leoch Xtreme Alpha Batteries
Thanks for the information! Gonna be under the drivers seat, powering LEDs, portable fridge, couple of 12v sockets.title edited : - Anyone recommend a good quality AGM?
Would you say 2 x 110Ah is necessary for your needs? What do you run off your batteries? I’m looking to just have a 12v compressor fridge, a few LEDs and a 12v water pump running, so sounds similar to @Dave Lawson . Obviously LEDs won’t take much and water pump will be used rarely and for very short periods of time.. so just the fridge that will be using majority of the power. Do you think 110Ah battery would be enough or should I go for a slightly larger 130Ah one and mount on its side?it depends on where you want to fit it? , due to physical size . . .
you might be able to fit a 95ah/110ah under a single seat base . .
but a 75ah under double seat base.
twin batteries in rear build?
so where to plan to fit it/them?
and to power what? - which like give an idea of size reqd.
more info here :
Bosch S5 A13 019 95Ah AGM is poular
Upgrading Starter Battery - how to guide
My van (April 2017 T28) is fitted with a Moll battery. I am experiencing some issues with it not starting after a few days sitting on the drive. Now this could be due to the tracker I have fitted draining it but I doubt it, I'll do some drain current tests before taking the plunge. If I were to...www.t6forum.com
S5 A13 Bosch AGM Car Battery 12V 95Ah Type 019 S5A13 START STOP | eBay
You must check against the battery currently fitted to your vehicle before ordering to ensure that this is the correct battery for your vehicle. Because of this, we put all of our resources into getting you new battery out to you as quickly as humanly possible.ebay.us
i have a couple of Leoch "12V 110AH Xtreme AGM Leisure Battery (XR1750) NCC Class A "
12V 110AH Xtreme AGM Leisure Battery (XR1750) NCC Class A - Alpha Batteries
12V 110Ah fit-and-forget AGM lead-acid battery for multiple applications (LOW-FIT). Also suitable for use as a starter battery (dual-purpose) – […]www.alpha-batteries.co.uk
I've got one of these too . . . : Platinum AGM Plus Leisure Battery 12V 100Ah AGMLB6110L : Amazon.co.uk: Automotive
these Exide AGMs have popped up occasionally too . . . : Exide EK800 AGM Car Battery Type 110/115 (3 Year Guarantee): Amazon.co.uk: Car & Motorbike
Yeh this is another thing I’ve been trying to factor in.. The fridge I’m thinking of is 45W 12v 50L compressor from Kiravans, I’m estimating it to consume about 1Ah/h given that it won’t actively be cooling 24hrs a day… please correct me if I’m way off there! So with a 110Ah or 130Ah battery hopefully should easily last a day or 2 off grid which is plenty for me as mostly will be using for weekends away, and will likely be driving an hour or so each day allowing the battery to recharge a bit with split charge relaya reminder you only get to use about half your A. H. for your calculations and don't deep discharge to often
