what wire do i tap into for the LEDs to work
tubs
Tiler
So question is what wire do i tap into for the LEDs to work ? Thanks
if you connect your LEDs Blue to the - brown/red (BCM switched 0v)
if you connect your LEDs Red to the - red/black (BMC timed +12v)
This will give you the same as the existing lights in the rear, ie power when door opened and will stay on till the time-out expires and will switch off.
This was copied from Dells earlier post..
Has anyone wired there interior spotlight off the existing lights, where they turn on when you press the key!? Or is it best to be direct from the fuse board? I would like them to come in when I press the key as well as the on a switch.
