LED Headlight Function
Pauly
VCDS User
Admin
Moderator
Can someone with LED headlights confirm the operation of the various lights please
When you key on three lights activate, the main strip around the perimeter of the headlight and the two small strips underneath the dipped/main beam lights. Do these illuminate at full brightness ?
When you turn the headlight switch to side lights is there any change ? do any of them dim or alter in brightness ?
When you turn on dipped headlights do they stay on/turn off/dim ?
When you turn on main beam does the dipped lights/side lights stay on/turn off/dim ?
Yes
Yes they dim
They stay on at sidelight dim levels.
Everything stays on. Everything. When indicating nothing dims like allot of other Drls.
Can someone confirm that dipped headlight is the outside led and main beam on the inside ?
Checked mine today and they only dim when you get to dipped headlights, off auto and sides are all full brightness.
So there's no change at all on yours when you turn sidelights on ? (As they are already illuminated)
