Laser Lamps - Worth It?
Discussion in 'General VW T6 Chat' started by kn0bby, 1 Nov 2019.
  1. kn0bby
    kn0bby Senior Member T6 Guru
    Map
    So back to driving home in the dark. Even my upgrades lights a not great.
    Took my wife’s car to work and her matrix led head lights are something else!
    I’m considering retrofitting factory LED headlights but the cost is huge.
    Which brings me to Laser Lamp LED grill lights. Anyone here running them? What are they like? Can they improve dipped and full beam headlights? Easy to fit?
  2. Tourershine
    Tourershine Senior Citizen. VIP Member T6 Legend
    Map
  3. andys
    andys Senior Member VIP Member T6 Legend
    They’re just spotlights aren’t they? Don’t think you could have them on with dipped beam
  4. Spaghettiboy78
    Spaghettiboy78 Mr Spaghetti VIP Member T6 Guru
    Map
    The title of this thread reminds me of this clip.
  5. kn0bby
    Map
    Thanks for the replies.
    had a look at @ROMANY TAMPIN van, it looks ace. The lights don’t look out of place.
    They offer an option with two positions. Looks like dipped to me.
  6. Skyliner33
    Skyliner33 Senior Member VCDS User VIP Member T6 Legend
    Map
    The light symbol in that diagram is full beam not dipped.
    Im petty sure after talking to @ROMANY TAMPIN about his these are spots and you will blind incoming traffic if they are on with dipped
  7. andys
    Yes I meant legally you can’t have them on with dipped beam
  8. Peatey
    Peatey Head Treacle Miner VIP Member T6 Legend
    Map
    @ROMANY TAMPIN has a separate switch on the dash for when he's going "Black Opps"
  9. dubber36
    dubber36 Senior Member VIP Member T6 Guru
    I saw these on a van at Busfest. The way they fit into the grille seemed a bit wobbly to me. Certainly not like Cibie Oscars on Theta Rally Brackets.
  10. Deaston
    Deaston Member T6 Pro
    Are the standard headlamps that bad, and the LEDs that good, that it's worth retrofitting?
    The headlights on my T5.1 seem fine. Is LED really that much better?
  11. Tourershine
    Map
    Yes. Yes and Yes in that order.
    It's a well reported issue that the standard halogen headlights are awful on the T6, with many companies offering alternatives. I have the factory LEDs and they are fantastic in the dark, and it would be the number 1 first option ticked on any orders in the future. Just take a look at the residual values of a factory LED T6 against the same T6 without LED. That alone justifies the initial cost of these when ordering new in my opinion.
    I wonder if the T6.1 none LEDs will be vastly improved over the T6 as it's such a wide reported issue.
    DaveD likes this.
  12. superflyguy
    superflyguy Senior Member VIP Member T6 Legend
    Map
    They are absolute Dog Sh*t.
    DaveD likes this.
  13. bullracing
    bullracing Senior Member VIP Member T6 Guru
    A lot of money for lamps which last and do the same as a lot of other makes. I run WOWLED bars on all my off road kits. Friends have Laser and Rigid. The wowleds are just as good with a tiny price, The difference is certainly not visible at night side by side. Last just as long.
    You may need to touch up if you scratch the steel parts to avoid corrosion as the paint is slightly thinner but the main part of the unit is ally so just the mounts. For the sake of saving a lot of money check out wowled lights.
    20191024_150454_resized.jpg 20190626_125236_resized.jpg 20190626_125246_resized.jpg 20190626_125258_resized.jpg 20190626_125306_resized.jpg 20190419_163405_resized.jpg 20190419_194445_resized.jpg
    ei-aprilia likes this.
  14. ei-aprilia
    ei-aprilia Senior Member VIP Member T6 Pro
    Good advice!
  15. Shaun Witts
    Shaun Witts Senior Member VIP Member T6 Guru
    There is an option with “position” lights, which is probably what that circuit is for.
  16. kn0bby
    Map
    what does that mean then? Am I being stupid?
  17. Shaun Witts
    I would expect that to mean sidelights, not dipped beam.
  18. bullracing
    Do you need a relay?
    I tend not to run a relay but use a switch and appropriate wiring. I dont run a relay as they dont like water much but thats just my setup. Either way you go and whatever lights you go for, You will not be dissapointed. SOOOOO much nicer at night being able to see everything. I wouldnt run them as dipped though. Just have them on a seperate switch ready. I used a carling switch.
  19. ROMANY TAMPIN
    ROMANY TAMPIN Senior Member VIP Member T6 Guru
    Map
    I have them
    I love them
    Turns night to day !! No kidding
    I have them on a separate push switch on the dash so I have full control. Wired as a totally separate system
    Tourershine likes this.
  20. dubber36
    On a road vehicle, surely they'd just be wired via a relay to operate with main beam?
Tags:
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
