The wire bundle should be close to the outer skin, no guarantees.
I’d put a stop on the drill to limit depth penetration, make the tapping with the shortest screw, remove the screw and grind off the point before refitting.
First steps on the journey to our new camper. Base van is a new 4Motion LWB, delivered yesterday. Ceiling panels out, and first fix of the wiring along the roof lines, in preparation for the pop-top to be fitted next week.
If you use the existing holes you could use the plastic expanding clips as per the other panels (depending on what you are wanting to attach to the pillars)
