Interior light timing
Diesel9a1
Bugs me that when you manually switch the light on inside, it still times out after, what, 10 mins? Reset by ignition on or door open close.
Another switch relay override required to put the interior light power onto the leisure battery then!
VW T6 designed by none drivers, simply Sunday shoppers, office commuters. Definitely not by outside railway shift workers!
Really irritates me aswell when working in the back. Must be possible to change via coding but I've never found anything with vcds
If someone left their lights on and flattened their battery they’d slag VW off for not putting a timer on it. Guess they thought 10 mins was a decent compromise. Best to have a better light attached to the leisure battery, you can position it so that it covers more of the van then.
