Interior light problem
Rob-Harrison1979
Hi all, recently encountered a problem where my interior light stays on when I shut my doors and the side repeaters don’t flash as I lock the van, I’m hoping there is an easy fix as it’s frustrating me lots lol many thanks
Welcome to T6F . . . @Rob-Harrison1979
Door lock sensor.
Check the dash display and see if.it shows all the doors closed..
Might need a code scan to find out which door is causing the issue.
Hi, yep I’ve a door open light on the dash, think it will the sliding door sensor, I remember pressing it as I was wiping dry the van after id washed it so I’ve done something to it, any ideas on what to do? Many thanks, Rob
Open and close the door a few times..
Clean the pin contacts on the siding door...
Lock and unlock a few times etc...
See if you can get it back to life..
Some people take some WD40 to the lock to free it up a bit.
Apparr from that it's get a Carista scan for codes, and take lock assembly out to check it.
I get that very occasionally. Mine clears after an open and shut cycle. Worth checking that the contact pins and socket are clear of oxidation as per @Dellmassive
Sorted this problem now, many thanks, the sensor was working fine turning the light out when I pressed it with my finger, sliding door wasn’t making contact, sorted it now, thanks again,
