I’ve just removed the cooler on my van, I don’t think the bigger “C” type cooler will fit, the mounting holes are completely different, the Audi TTRS uses the DQ500 DSG box, so I would have thought the coolers would fit the same?
Also, removing the original cooler from the top was an absolute swine! Shoehorning the bigger one in would be extremely difficult.
I've been looking for DSG coolers, as I use the van for towing, and sometimes feel the DSG getting 'notchy' with a heavy trailer and right foot. Whilst surfing for such, I came across Bar-Tek Motorsport and their DSG temperature monitor;
Also what some of the mega mapped Golf Rs do is put a couple of fittings on to the mechatronic cover, then have an external electric pump and oil cooler to just circulate the DSG fluid and cool it. It seems clutch clamping pressure is done by fluid pressure and they see clutch slippage at high BGP due to flow restrictions introduced by an inline oil cooler. Also has the advantage that you stand a better chance of getting home if you hole to cooler.
For T6 OBDlink offers only generic OBD data - thus just selected engine data - unfortunately oil temperature doesn't belong to basic OBD parameters.
Manufacturer specific additional datasets would be under: Settings > Get Enhanced OEM Add-Ons
Alternatively you could build your own dataset under: Settings > User-Defined PIDs
Alternatively:
CarScanner app has quite a few datasets available - I believe even the free versio of the app will do.
E.g. connection profile below has the requested parameters (below a snapshot from CXEB engine + DSG + 4Motion)
Thanks @mmi, you've become the voice of reason for data analysis!
This is exactly what I was looking for, I've already got the OBDLink MX+ which works well with the Car Scanner Pro app which only costs £7.99 for the forever contract.
I'll head out to have a play and see what I can do with it.
