On mine it only works if I shut all doors, open drivers door and press button on B pillar, it lights up, then close drivers door and lock with fob, you will know if its de activated as deadlocks don't engage, 1 clunk instead of 2 on locking vanHi All,
I am unable to disable the interior alarm sensors as per the attached video, can anyone offer any advice?
I have checked the switch and nothing looks out of the ordinary with the internals. I pressed the lower section of the button but see no change in the LED colour, mine stays red with no change to the interior sensors.
How to disable the T5/6 interior alarm sensors.
same as mine
All other doors shut?
Wot ee said!On mine it only works if I shut all doors, open drivers door and press button on B pillar, it lights up, then close drivers door and lock with fob, you will know if its de activated as deadlocks don't engage, 1 clunk instead of 2 on locking van
hope this helps
Ignition off, drivers door open, then pullress the button(its a finger hook like the tailgate switch)and it will turn yellow
What happens if it doesn’t turn yellow?yeah thats what i said
you will know if its working by listening when you lock, should only make 1 clunk not 2 if interior alarm is disabled as this also disables deadlocks I believeWhat happens if it doesn’t turn yellow?
Did it, I pressed the interior disable button pressed the key fob and double lock. Seems the button isn’t playing ball or I have a loose wire somewhere.you will know if its working by listening when you lock, should only make 1 clunk not 2 if interior alarm is disabled as this also disables deadlocks I believe
Have you had it scanned with vcds?Did it, I pressed the interior disable button pressed the key fob and double lock. Seems the button isn’t playing ball or I have a loose wire somewhere.
Any suggestions?
Did obd11 not come up with any faults? Maybe we should have scanned your van at SouthportI don’t have VCDS as I sold it when I sold me GTI @Skyliner33 I only have OBDeleven at the moment.
To verify switch operation (T6) with OBDeleven:I only have OBDeleven at the moment.
