How To Check Gearbox Oil?
Alanmh
I am probably paranoid, and I am used to driving cars with the windows up and lots of sound deadening. But, I am noticing a whine noise on overrun from the gearbox, especially in second gear. With a big trip to France coming up, how do I check the gearbox oil level.
As I say, its probably just because I have the windows open in this weather and its a van, but don't want to be worrying about it on the 8 hour drive to the Dordogne. Thanks for any advice.
Dellmassive
204 T32 DSG LWB SPORTLINE PV MY18
VCDS User
Moderator
T6 Legend
what year/engine/gearbox/final drive?
see below for the 6speed manual box : Oil level is correct when gearbox is filled to lower edge of filler hole.
When filling with oil, note the following:
– Remove bolt -arrow-.
– Fill with gear oil to lower edge of filler hole.
– Screw in bolt -arrow- with new seal and tighten to specified torque → Fig..
– If present, attach noise insulation to gearbox.
Capacity of manual gearbox 2.7 l
and
Checking gear oil level, bevel box
Note: Bevel box is bolted to side of gearbox and has its own oil supply.
– Remove oil filler plug -arrow-.
Oil level is correct when bevel box is filled to lower edge of filler hole.
– Tighten bolt -arrow-.
– Install any noise insulation
Capacity of bevel box 1.2 l
Alanmh
Thanks for the answer
Sorry I should have said. It's a 5 speed 102 engine euro6, late 2016 on a 66 plate.
What is the bevel box?
Jmec
and
Hi, the Bevel gear oil..what type? VW want $90au for one litre and no oil manufacturers list it.
