I have a walk in wet room that has a separate pump and tank for the huge shower head (positive head, I think it's referred as). The pump has been playing up for a few years now, and it often takes a while between switching the tap on and the pump firing up, sometimes tapping the side of the pump worked, other times it just came on around 30 seconds after the tap was switched on. We just got used to the way it worked. It's been installed in my house for around 8 years and used to work perfectly, instantly firing up when the tap was turned on.
Well, it seems to have packed up altogether today. I tried to have a shower and the pump never actually came on, but it is pretty hot, so I assume it's finally given up.
My question is this: The newer versions of a Salamander CT50 Twin look totally different to mine. Does anyone know if the newer version is the same pump and it will just replace like for like.
Here is the new version Salamander CT50XTRA 1.5 Bar +ve Head Regenerative Shower Pump
Here is my current version.
Rather than just taking a punt that it will be the same, I thought i'd ask in here because I know someone will instantly know the definitive answer.
