HI I'm nick from North Cheshire this looks a quite active group.
I dont own a VW myself but my daughter and her hubby do....a 2015 T5 2lt TDI converted by themselves to a camper....I sort out a lot of her TECH probs.
One I need help with is getting hold of a new set of HP fuel injection pipes...all 5....all 5 on her van are very badly corroded.....never seen fuel injection pipes rot like that....is it common on the T5.
Her mechanic has told her a full set of HP steel pipes is going to be around £400 from VW.
From what I have found out the the T5 engine is fitted to some other VW cars ect.....can anybody a suitable donor car.
Or who is the goto place for T5 parts used or new.
She needs a new set of HP fuel pipes as the engine has a very lumpy idle....its fine once under way....and her mechanic thinks its the fuel regulator screwed into the end of the common rail tube.
All the injector union will need to be undo....and look like they will fail if disturbed
Over to you guys.
Over to you guys.
