CALLAKN Electrician / Linesman VIP Member T6 Legend 29 May 2022 #1 Hello guys, Use to be connected to my victron for years and now it’s not interested and won’t let me view data lol Any help appreciated Cheers Callum
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 29 May 2022 #2 Delete the BT pairing on your phone. Then re pair again. The default code is 000000 ... Unless you have changed the pin code in the past..... If that's the case enter the pin you changed to.
CALLAKN Electrician / Linesman VIP Member T6 Legend 29 May 2022 #3 Dellmassive said: Delete the BT pairing on your phone. Then re pair again. The default code is 000000 ... Unless you have changed the pin code in the past..... If that's the case enter the pin you changed to. Click to expand... Doesn’t even show up on the bt!!
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 29 May 2022 #4 Ok. But the app sees it, so did you try the default password. ,000000? Do you remember changing it?
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 29 May 2022 #5 To reset the pin... Press and hold the mode button for 10sec untill lights blink. Then use default password.. 000000 https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.victronenergy.com/upload/documents/Blue_Smart_IP65_Charger_manual_230V/Blue_Smart_IP65_Charger-en.pdf&ved=2ahUKEwicnejJgIX4AhWISsAKHTJUDBwQFnoECAcQAQ&usg=AOvVaw1X-AoJ52NkHcBMgA5ev2s2 .
CALLAKN Electrician / Linesman VIP Member T6 Legend 30 May 2022 #7 worked a treat - cheers lee, legend as always
