Startline retrofitted MFSW not working
I will put your long code into my VCDS to see if you have byte 9 bit 3 set to 1 byte 15 bit 0 set to 1 and byte 29 bit 6 set to 1
This should allow you to set Subbus MFL to Hex B4FFFF from B5FFFF
THEN in 5F (info electronics)
In adaption
Scroll down until you find Car Function list CAN2 and set MFL to Available
Then
MFL message bus to Terminal 15.
I will send you the instructions with screen shots but obviously disregard the cruise control stuff.
Read through the CHANG1 'how-to-retrofit-mfsw-and-cruise-control-to-t6-eu6-2019-startline-also-hacking-dsg-paddles-for-ccs' and use the step by step's as comparison as to what you have done … it will more than likely be that you have a wire still in situ or wire in wrong location .. mine was .. Good luck
