Startline retrofitted MFSW not working
09 is the address or word as used in the old days for the BCM designation in the ecu locations.
Yes I think you need the red illumination. A friend of mine fitted MFSW with cruise but white buttons and had to change to red, then it worked, but I haven’t tried playing with the coding for non CCS buttons.
Just out of interest when you go into 09 the BCM, do you get MFL show up in additional control units under the sub headings?
As for the airbag loom, it will be the same, the wire in pin 5 is for cruise buttons and goes to pin 11 on the other side of the clock spring
not sure if this’ll make any difference, but the Passat MFSW I just fitted to my 2015 Euro5 Highline was from a Passat.
Same button layout. But white illumination.
Works fine.
They are fairly easy to swap out if you take your time. Check and see if it shows the part number in your scan info.
This is the part number for the MFSW that came with my van (the swap was so I wouldn’t be without a wheel whilst it was reupholstered):
