Heater Blower Speed
Discussion in 'Vehicle Faults Warranty Repairs Issues & Problems' started by HHO, 3 Dec 2018.
  1. oldiebut goodie
    oldiebut goodie Senior Member VIP Member T6 Guru
    Now what is needed is a mini duct to blow air over the resistor once the blower is operated to keep it cool.
  2. Wills
    Wills Senior Member VIP Member T6 Legend
    So is it the resistors that overheat that cause the thermal fuse to fail? If so, a thermal heat sink may help?
  3. Dilbert
    Dilbert STOPPED traveling... VIP Member T6 Guru
    Map
    The resistor pack sits in the main blower air flow duct for cooling. I have suspected the problem is the resistor pack getting too hot on speed 1 - so less air flow. Mine have always failed when on speed position 1.
    Of course it could be due to a faulty blower motor drawing too much current causing the resistor pack to overheat. This is where the thermal fuse is designed to do its job.
    All I know is my blower motor appears to work OK and no immediate failures when a new resistor pack or thermal fuse is fitted.
  4. Pete C
    Pete C T30 102bhp converted to camper VIP Member T6 Legend
    Map
    My wife’s Ford Fiesta blows the resistor pack about once a year. It’s a common theme on various cars - that’s why EBay has loads for sale.
    Pete
  5. oldiebut goodie
    I should have said the over the thermal fuse rather than resistor. Brain is out of gear! There must be a safe fix for this fault rather than keep throwing new resistor packs or thermal fuses at the problem.
    Was it the lack of a thermal fuse the cause of those vehicles that kept bursting into flames?
    If it is the position 1 that causes it my solution would be to disconnect that speed if at all possible without causing a further problem. My thinking is that position 1 is such a low airflow it would not be missed much.:)
    DXX and Robert like this.
  6. Wills
  7. oldiebut goodie
    That's my theory out of the window then!
    Wills likes this.
  8. Wills
    Even though my van’s in warranty, I decided to replace the thermal fuse myself today to spare me the hassle and gain experience for future fixes!
    It was a simple fix using a fuse off eBay and how satisfying it was too.... All up and working for £1.10p.
    mmi, Robert and Dilbert like this.
  9. mmi
    mmi Senior Member VCDS User VIP Member T6 Legend
    Map
    I'd say it is only speed/stage 3 that can blow the fuse. As above the current to the blower travels through the fuse only at switch positions 1-3.
    A measurement of current draw of the blower. Obviously there is some variation depending on voltage, air density (cold air=more dense), blockages on airway exits, etc. Most likely did the measurements engine off, so they could be a bit higher engine running. Obviously need to have another session...:geek:
    Stage 1 = 3.3 A;
    Stage 2 = 5.4 A;
    Stage 3 = 10.2 A;
    Stage 4 = 18.9 A.
    EDIT: picture manipulation
    Robert and Pete C like this.
  10. Pete C
    Map
    And this is why I love this forum - proper detailed analysis and geekery (sp?) when needed :)
    Pete
  11. oldiebut goodie
    But we are not worried about the current here surely? It is a thermal fuse and the resistor will get hottest on position 1. Taking the temperature at the various speeds would be more informative.
    mmi and Dilbert like this.
  12. Robert
    Robert Senior Member VCDS User VIP Member T6 Guru
    Map
    In this configuration speed is controlled by reducing air blower motor supply voltage.
    Speed adjustment is divided in 4 stages, obviously disregarding no supply voltage (Stage 0).
    When Stage 4 is selected(max motor speed) full supply voltage is directly connected to the motor and overheating fuse is effectively bypassed.
    If Stages 1, 2 & 3 are selected motor speed is reduced accordingly and supply voltage is connected via corresponding resistor/resistors and overheating fuse.
    As the overheating fuse reacts to excessive temperature and not to excessive current I am convinced that this problem is down to the quality of the fuse itself.
    Unless there is a problem with the air blower motor and then excessive current would be sufficient to cause the thermal fuse itself to heat up to the trigger temperature.
    mmi likes this.
  13. oldiebut goodie
    You may well be on to something with the quality of the thermal fuse - after I replaced my shower fan one with one with the same value I have had no further fuse blows.
    What worries me is the number of replacement resistor packs that are offered for sale for all varieties of vehicles, does this mean that this means of varying motor speed is not up to the task generally?
    ( When you see the old Webasto glow plug resistor you can see the lengths to which they went to ensure good heat dissipation, open coil of resistance wire on a ceramic core on a heavy steel enclosure that had to be affixed to steel heat sink piece of bodywork):
    Robert and mmi like this.
  14. Robert
    Map
    It is typical manufacturer's approach these days across all industries to design equipment not to last. Another words to fail after reasonable amount of time and to force consumers to buy replacement components. Also component replacement setup/procedures are designed to maximise consumers expense and therefore maximise manufacturer's profit. Rip off across the board :(
  15. oldiebut goodie
    Here is the T3 solution to the problem - VW Electrics Dash Fan Control Upgrade - VW T25(T3)-Tech using a PWM motor controller instead of the resistor. Here it is a mixture of the resistor melts surrounding plastic and the switch contacts burning out. As to whether something like that would be suitable for integrating with the T6 electrical system I don't know, I suppose it would need to be part of the design right from the start.
  16. Robert
    Map
    PWM is the best speed control method for a DC motor.:thumbsup:
    But as I already said VW is purposely cutting costs and creates circumstances to make more money.:(
    DXX and mmi like this.
  17. Dilbert
    Map
    Could be done as a plug and play solution quite easily. VW won't as @Robert has said due to cost.
    PMW (pulse width modulation) is really a bit of an overkill for a non-ctitical motor speed though. But it would be more efficient.
    mmi and Robert like this.
  18. mmi
    Map
    Measured front blower current (engine off):
    Stage 1 = 3.3 A;
    Stage 2 = 5.4 A;
    Stage 3 = 10.2 A;
    Stage 4 = 18.9 A​
    At 20 °C the resistor values are:
    R(St1) = 1.24 ohm
    R(St2) = 0.82 ohm
    R(St3) = 0.38 ohm
    Blower (off) = 0.50 ohm
    Thermal fuse has identifier 192KR1.
    Power dissipation (P = I²R) at different stages would thus be:
    Stage 1 = (3.3A)² x 2.44 ohm = 27 W
    Stage 2 = (5.4A)² x 1.20 ohm = 35 W
    Stage 3 = (10.2A)² x 0.38 ohm = 40 W​
    However, the resistors seem to be PTC resistors and cooled by airflow thus a bit more evaluation is needed...
    Fortunately I have another blower in load area where access is easy so it may serve now as test platform.
    Dilbert, Robert and Pauly like this.
  19. mmi
    Map
    It was another school day o_O Such a simple device - a blower series resistor for regulating fan speed - been in use for decades...
    Turned out to be a multidimensional challenge - electrical efficiency, heat conductivity, fuse cooled by airflow, heat transfer function, etc.
    Anyways, thanks again for the inspriration to the members of the Forum, now especially:
    Test setup to emulate front heater fresh air blower:
    The protocol:
    Note: This is not the temperature at thermal fuse - just on resistor surface having a sensor glued there and covered by a foam patch. Would be another challenge to pick it up on/in the fuse. Just wanted to clarify to myself what's going on in the neighbourhood.
    Actual wiring diagram used in the test- same principle and pinouts as for front blower (shown earlier in the thread).
    However, under slightly different conditions... pushing up battery voltage, intake air temperature... :speechless:
    DXX, Pauly, Dilbert and 2 others like this.
  20. Dilbert
    Map
    Excellent work there @mmi:thumbsup::thumbsup::thumbsup:
    Interesting the resistor surface temperature on speed 1 is 180 deg. As expected - maximum voltage drop, maximum dissipation. It would not take much to increase the dissipation; i.e. Increased input voltage or higher current draw by a cold motor with stiffer bearings/bushes, and then you could get to 192 deg fuse level. The fan motor could be running slower so less air flow too over the resister pack and fuse.
Tags:
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
