Now I've thought about it, I remember that the panel with the light switch is actually fixed to the van with a screw inside the light switch recess, meaning you have to get the light switch out before you can take the screw out and the panel off. So, I must have got to the light switch clips with the panel only loosened. Make sense?Small side panel is off & there is no way in from there thanks for your input though.
I'll mention again, this is all on a T6.1
Have you seen this;
Dashboard modifications
Hi. Looking to fit the centre console when funds permit. Any tips on removing the original please. It's quite straight forward to remove ,lower glove compartment and pannel below that need to remove first ,the drivers side panel under steering wheel and the lower panel need to be removed . If...www.t6forum.com
I think you'll struggle if the mech is broken. I think you'll have to break it off and replace the bezzel and switch.
There are 3 locking points from memory, spaced equally around the edge. The switch sits in a round moulding which has one screw at 6O'clock holding it onto the dash .
