Well...yes, but why, is it such a daft idea to do thatHave you been drinking?
AbsolutelyFetish ??
Thanks @Pauly . Yeah, I will look at the seat mod instead. I did here of people slightly adjusting the arch but it does sound a little drastic. I have already angle grinded the base but the seat pad still hits the arch unless I lift it slightly.Think it’s more normal to modify the seat not the wheelarch
Thank you @Ann3x . A great help and looks like the sort of distance I need. I will have a look at the seat first but may have to flatten a little. Thanks for the picsI've flattened mine a bit. Helps my reimo slide to the far left. Pics:
View attachment 72899View attachment 72900View attachment 72901
It's probably about 0.7-1cm flattened. I found that just hitting it with a lump hammer wasn't the best way (looked really uneven), so I got some flat wood and hit that which took some time but eventually worked well. Doesn't look as pretty as stock but definitely not too bad.Thank you @Ann3x . A great help and looks like the sort of distance I need. I will have a look at the seat first but may have to flatten a little. Thanks for the pics
Superb, thank you.It's probably about 0.7-1cm flattened. I found that just hitting it with a lump hammer wasn't the best way (looked really uneven), so I got some flat wood and hit that which took some time but eventually worked well. Doesn't look as pretty as stock but definitely not too bad.
It got me around 5cm extra lateral space I think which allowed me to fit a bigger fridge whilst maintaining full slide on my rails - so well worth it imo.
Check your seat can slide across enough before doing, mines a variotech 3000.
Good luck
Thanks @Ads_Essex . Yes, saw your post but I dont understand how that mod lifts the seat pad. Is it just angled to make it go back further rather than lifted?I had the seat pad modded to fit. It needed a bit of cutting, bending and welding. Only cost me £20 at a fabricators’.
No, the metal is bent upwards (to reflect the opposite side) with a little bit of cushion cut away.Thanks @Ads_Essex . Yes, saw your post but I dont understand how that mod lifts the seat pad.
Okay thanks mate, will have a look at it.No, the metal is bent upwards (to reflect the opposite side) with a little bit of cushion cut away.
Do you do accident repairs too?It's probably about 0.7-1cm flattened. I found that just hitting it with a lump hammer wasn't the best way (looked really uneven), so I got some flat wood and hit that which took some time but eventually worked well. Doesn't look as pretty as stock but definitely not too bad.
Good luck
Lump hammer fixes all....Do you do accident repairs too?
Sounds like a good solution though, does it impede the space or fit of the wheel arch outer plastics?
