This is needed as part of a longer guide to removing and swapping doors, but I know this is a good subject for anyone who needs to sound deaden and insulate their van. A great deal of thanks to those on this thread which kickstarted my work today.
First you'll need to remove the door card. You also need to remove the lock barrel on the exterior door handle although it's a good idea to leave the handle on.
Then you will need to disconnect some things from the carrier assembly - that's the large aluminium plate to which is attached the window motor (and window regulator/slides behind), door locking mechanism (hidden top left), speaker and loom. This is the passenger side, the driver's side is almost identical. And, because this plate carries the window, you need to detach the window from the plate too.
Pull off the two circular covers to reveal the window regulator (rails). Wind the window down (using the driver's side switch panel, or reconnect the passenger switch panel briefly) and stop when the carriers are visible (like in the picture). Using a 10mm socket, release each clamp a little until you can pull up the window by hand.
Secure the window at the top with tape (not this tape, it's terrible to get off, but strong).
Pop out the cable from the door handle.
