Gearmate Internal Drawer System
Jon Birkett
Hi has anyone used the gearmate system on a T6 Kombi?
Just looking for a picture if someone has
Jon
No links other than the catalogue but had an email from gearmate with the right dimensions they can custom build. However some rough measurements base on a SWB Kombi is that most of the draw systems will fit it’s the cover that would neatly create a level platform wall to wall. But based on the wheel arch being about 350mm very rough measurement. Then only the 500mm high single or double draw system will fit. What I need to check is how 500mm high works with the rear seats as the length of the draw system is quite tight anyway. Will dig some more
