so vw says with the reverse sensor
So does that mean the oil has to be carefully measured to go back in? The filler hole is usually sets the level too.so vw says with the reverse sensor
the only option is to measure it. but vw says 2.7l and someone added 0.1So does that mean the oil has to be carefully measured to go back in? The filler hole is usually sets the level too.
Measure what comes out in a jug, hopefully it should be near the 2.7ltrs quoted, gives you an idea of what should go back in, unless you've a leakSo does that mean the oil has to be carefully measured to go back in? The filler hole is usually sets the level too.
@BigYoeKing - did you end up refilling via the reverse sensor?What is your experience with aftermarket gearbox oils? the original is G052527A2. 3xbottles for 160euro
