brookster69
I have recently fitted the vw drl lighting kit to my transporter lwb kombi 180 dsg highline and wired it exactly as per the vw instructions, I also upgraded the standard yellow glow drl bulbs for some brighter ones, all seemed fine, except a couple of days later the bulb icon came up on the dashboard. I now have the rear passenger sidelight out and the front tiny passenger sidelight out, I have checked the bulb at the back and its fine, has any one got any ideas, I took the fuse board cover off inside below the gear lever and then put it back on as there is nothing to tell me which is which, just in case it is a fuse problem, has anyone else had this problem, or does anyone know which fuse controls the side lights on the passenger side, thanks brookster
