Sold FS: VW T6 Sliding Door Blind - Part Number 7E5 861 323 81U
pixelmix
I have a T6 sliding door blind which is part number 7E5861323.
It was described as a T6 sliding door blind for the left hand sliding door but it is not a match for my Caravelle blind, so make sure you check your part numbers rather than assuming as I did!
It is black - never fitted or used.
The photo doesn't show it very well, but obviously it is the black mesh blind. It is unmarked - the "marks" on the blind are obviously just the carpet behind.
£100 posted please (just recovering the money I spent on it)
The top cover piece definitely isn’t symmetrical although you could keep your existing top cover. I would need to look at the rest of it. I can take photos when I’m home if that helps.
I’d definitely recommend seeing if it is similar type to yours though. It is a few cm wider than my type
It is not symmetrical unfortunately - the metal bar on the other side is only 3/4 of the length of the whole unit.
I'm not sure if that would make a difference, but it might!
