Front OPS DIY - can I actually do it?
John A
Off of VDub Radio
VCDS User
I want to retrofit front OPS to my 2016 T6 Highline.
I can buy a complete kit, with the grills/trim, from CarSystems in Poland for £375 plus post.
Taking the front bumper off is my least favourite bit, but how hard is the rest of it for those that have done it?
I can code the kit myself.
Its an ok job, as long as you are happy removing and replacing a few dash trims and the bumper then you should be fine
If you already have rear sensors then there is no coding as its a replacement module (whch is already correctly coded)
The fiddly bit is prob getting the dash button in and joining the wires for it as it needs to tap into an adjacent button for illumination feeds
Thanks Pauly - the bumper is probably the bit I'm least confident with.
When I fitted the headlights, I couldn't line the bumper back up properly and ended up breaking one of the supports. I had to take it to a bodyshop with some new parts to have it done properly.
