Front Floor Mat Removal.
LambethBoy
204 DSG 4Motion
VCDS User
Hi all. Is there any instructions on here on how to remove front floor mat?
Apart from obviously removing the seats, is there anything else substantial? Tia :thumbsup:
You might find it easier to remove the door steps and handbrake tension cable. Simple when you can see it.
To get the steps off you also have to remove the b pillar covers and lower seatbelt bracket.
You will also need to remove the under dash trim panels to unhook the front edge of the flooring but it’s only a couple minutes to take a couple torx screws out
