Front Door Sound Deadening
dave_b
Is there an easy way to get deadening Matt behind the middle skin so the Matt goes on the actual door ?
Thanks. It’s the next bit I’m asking about. Once the door card is removed, there is then another bit that holds all the gubbins. I want to get some deaden matt behind that onto the actual metal of the door
You can remove the metal plate but first you need to release the glass from the window mechanism. Once that’s done secure the glass at its closed position with tape (it needs a fair amount). The plate can then be unbolted and removed giving you access to the rear of the plate and the internal side of the door skin.
Yes, that's the second guide that I linked to. Removing the carrier assembly
