Cornering fog lights can be turned off using VCDS or Carista. They can be changed for White LED's, you'll need to fit a resistor to fool the bulb monitoring system. While they will look better being white they won't light up the road as good because the light source on the bulb itself will be in the wrong place for the reflector. I got mine from here T6 LED Fog Light Bulbs & Resistors
Same here mateCheers @Deaky - I'm not bothered if they don't light up as clearly - I almost never use front fogs anyway. I might just turn off the cornering function then I won't have mates telling me I've got a foglight out!
I changed mine to led. Not got a photo of them at night though. I’m very pleased with them.
That's exactly what I want! Looks 100% better.
I bought these and they are great...
https://www.amazon.co.uk/dp/B01LER2ICU/ref=cm_sw_r_cp_api_d4DDBbJNDM354
You cannot really how they are installed from the pictures, but not a difficult job and no canbus errors.
Nice! Did you go for the 880's or one of the others?
No, they are standard H11 lamps just white (blue glass) instead of yellowSo @Pauly will the forum shop bulbs bring up a warning?
if no errors or bulb out warning . . . . . . why do you want to fit resistors?Can anyone tell me how to fit the resistors? I can't see a video anywhere. To be honest, I'm not getting any error lights on the dash
