1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fog Light issue
Discussion in 'Vehicle Faults Warranty Repairs Issues & Problems' started by Mupp3tt, 30 Nov 2016.
  1. Mupp3tt
    Mupp3tt Member VIP Member
    So I'm having an issue with my fog lights, and completely separate from each other.
    Like most I leave my lights on "auto" (fog lights off) jump in and out of the van and never really worry.
    Recently when you turn on the ignition, and start the engine, ONE of the two fog lights will also turn on. (which one is random) (this only happens when the engine is running, and if the ignition on but not having the engine running it doesnt happen), The other thing I have noticed when physically turning on the fog lights is that I cannot see the "cornering" function working. Has anyone had these issues. I'm waiting for my dealer to call me back.
    Spec is a 204PS HIGHLINE with LED headlights, heated washers etc....
  2. Loz
    Loz California 204 DSG 4Motion MY17 VCDS User Admin Moderator VIP Member
    This will happen if you leave the steering turned when you park up. What you are seeing is the cornering light function.
  3. Mupp3tt
    ??? Ok so do the fog lights turn on one at a time while driving? is that how the cornering function works? I assumed they would be motor driven, ie directionally trun but both be on... off out to try this out
  4. Loz
    Correct, the fog lamp reflector is designed to spread the light right to the side and at low speed the lights operate one at a time according to your steering angle.
  5. Pauly
    Pauly Senior Member VCDS User Admin Moderator
    Fogs are static, turn the wheel right (or indicate right at the correct vehicle speed) and the right fog will illuminate and vice versa for the left side
    When fogs are manually turned on you will see no change as they are already illuminated
  6. Mupp3tt
    ohhhhhhhh,, feeling mightly stupid right now..... ha ha .. oh well my child lock on the sliding door still majically reingages.. maybe I should go check that too ...
    Rob and Walski like this.
  7. DaveyB
    DaveyB Senior Member Moderator VIP Member T6 Legend
    Agree with Pauly and Loz, the only difference with the cornering function is when you're in reverse as they both come on and it has no bearing on which way the wheel is pointing.
  8. steve
    steve Member T6 Pro
    Ah ha! Was worried about my fog lights. Couldn't figure out what was going on. Neighbour told me one of my lights was out so I checked them and everything was ok and both dogs were on. Then next day I noticed only one light was on. Then I saw in reflection of shop window one of the lights actually turn on as I was cornering.
    Had no idea they did this. Seems a tad odd and I imagine I'll get lots of people telling me a light has gone lol
    Do the fogs come on automatically when in have lights set to auto? Or do they just come on one at a time when cornering at low speeds?
  9. Caravellet6
    Caravellet6 Senior Member VIP Member T6 Guru
    They come on cornering at low speeds or indicating, also both come on when reversing! It's a common VAG thing my Skoda does this as well.
Share This Page
