Not happy. My 2017 T6 Van came back from the Converters with the rear camera and parking sensors not working. When I engage reverse I just get a 5 second (or so) tone and no parking display or camera image. VCDS pinpointed the nearside rear parking sensor as the problem area so I removed both this one and the 2nd sensor in of the 4 rear sensors and measured them on an ohmmeter. The nearside one showed a short circuit between two of the pins, whereas the second one in did not, so I assumed then this would mean the nearside sensor was faulty. I swapped this with the second sensor in and gave the van to my local VW dealer expecting VCDS to show the fault had now moved to the second sensor but it didn’t. The VW Main Dealer spent 2 hours on this, and concluded the fault is in the wiring between the sensors at the back and control module under the dash. They take they view that this means that the Converters have driven a screw through the wiring somewhere and therefore their time spent is not covered by the warranty. So now I am £200 down and no nearer finding out where the fault lies. Is it possible that 2 sensors can show quite different resistances between their pins yet both be working?
If the fault truly is somewhere in the wiring, can someone point me at the part of the wiring diagram which shows how the individual sensors are wired back to the Control Module. During the Conversion I added a set of spare wires from under the dash to the rear of the van for future use, so if all else fails, I may have to reroute the connections via my own wiring direct to the nearside parking sensor on the rear bumper.
If that is the case then I need to know a) where the control module is under the dash and b) what connections I need to use. I note that the parking sensors have 3 connections. Do all 3 connections go back separately to the Control module or are some of them common to the other sensors?
