My T6 Highline is nearly 2 years old now and its been back to my local dealer several times with what i think is a lighting issue, each time im fobbed off with one excuse or another and am now getting rather irritated.
Heres the situation. If i have my light switch set to manual on the control and only the drl's are on and i VERY QUICKLY flash the lights (for example to thank someone for giving way) only the offside headlight will flash. The only way that both will flash together is if i hold the stalk on the side of the steering wheel back for longer or if the headlights are on when i flash. If any of you out there have factory fitted led's may i suggest that you pull up in front of a shop window or garage door in the daytime and try for yourself as I've got a sneaky feeling that i might not be alone with this issue. Im aware that there will be a millisecond delay between pulling back on the stalk and the power getting to the headlight flash but surely both lights should flash together - just like my Morris Marina did back in the day!
