This is the repair work that VW have carried out since June and their reply.
In June the vehicle visited out van centre with the engine management light on (30/07/2020 at 53012 miles) we carried out a software upgrade for a the fault recorded, the repair solution provided by Volkswagen was related a code stored for add blue system, this repair included a software up-date and replacement of a EGR Pipe.
In October the engine management light was on again (28/10/2020 at 57099 miles) The fault on this occasion was related to a pressure sensor which is built-in to the glow plug on cylinder number three, during the replacement of the pressure sensor. Following the replacement of the pressure sensor we also re-generated the DPF filter as part of the process instructed from Volkswagen UK
As you are aware the engine management light is again back on (06/11/2020 at 57679 miles) due to the above repairs being carried out recently I instructed the team to investigate further at no cost to yourself. At this stage we made contact with Volkswagen technical Volkswagen who have then instructed us to check the measuring values for the NOx sensor after the initial warmup period, these values came back ok. The next instruction from Volkswagen technical was to check the add blue injection system which also checked out ok. We were then informed that an EGR test would be the next step this also checked out ok. After this it was requested we check out the exhausting in-take system for leaks both of these checks came back ok. Volkswagen then recommended we remove the intake sensor and check in the intake manifold for carbon build-up. This image was sent to Volkswagen deemed the build-up of carbon on the sensor to be excessive and requested we stripped down the front of the engine and inspect, intake manifold valves and ports on the cylinder head these also had a build-up of carbon.
They are now suggesting I pay for it because it is fair wear and tear. Never have I had a vehicle do this at this age.
