Enable Android Auto without hefty dealer charge?
TonyR
Hi does anyone know of a work around enabling Android Auto on our T6 without having to go through expensive dealership cost?
There isn't one :thumbsdown:
The only option apart from dealership is a local specialitst/hacker. The advantage of this kind of approach is that you are getting all of your infotainment features activated in one go. There is one guy in Ireland who does it for €180=£150.
And by the way, how much is dealership cost?
Reactions: mmi
Thanks:thumbsup:
Here you find some extra info ---> Infotainment Fec/swap
Great thread but i'm in same boat as below screenshots so guess i need someone with a VCDS :(
  1. 6700094a-c4ce-4f65-99b3-2e63dc369274-jpeg.51929
    This has come up - I’ve got loads of sub-menu’s.. none of which look like yours with the numbers beside them.
    f74b1eee-3651-4b58-9014-85dba321f6d8-jpeg.51930
    Team Silver
    Ads_Essex, 1 Oct 2019Report
    #6Like+ QuoteReply
    RobertSenior MemberVIP MemberT6 Guru
    Map
    Just try to hold you menu button for a little bit longer.
    In some cases you may need to activate developer mode with VCDS in adaptations under Infotainment.
