G Graeme_B Senior Member VIP Member T6 Guru 21 Aug 2022 #1 I've got an issue with electrics. I've found one fuse for the alarm/horns abd replaced but still no joy.
G Graeme_B Senior Member VIP Member T6 Guru 21 Aug 2022 #2 Is there anyway to override the central locking to open the passenger door?
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #3 Graeme_B said: Is there anyway to override the central locking to open the passenger door? Click to expand... The internal pull handle will unlock, open the door. Unless the door is deadlocked. In which case you need to un deadlock it with the key in the drivers door or via the fob electronically.
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #4 Any idea what caused the original problem? ... Post a few close up pics of your SC fuse box. The lower dash one.. To check against any fuses being missing or in the wrong slot.
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #7 What spec van?
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #8 T6 - Fuse Card Reference chart for T6 Fuses. www.t6forum.com
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #9 Graeme_B said: I found 2 fuses gone. Click to expand... gone as in missing? or blown? what two fuses?
G Graeme_B Senior Member VIP Member T6 Guru 21 Aug 2022 #13 Have replaced sc44 twice now and blows each time
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #14 T6 - T6 Fuse Layout SC,SD,SF (NON-CALI) T6 Fuse Layout SC,SD,SF (NON-CALI) www.t6forum.com check SC44
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #15 Graeme_B said: Have replaced sc44 twice now and blows each time Click to expand... what size fuse is it?
G Graeme_B Senior Member VIP Member T6 Guru 21 Aug 2022 #17 Don't think we have any more of that size
G Graeme_B Senior Member VIP Member T6 Guru 21 Aug 2022 #18 Tbh if i can open passenger door would be fine
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #19 then you must have a fault on one of these circuits. . .
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 21 Aug 2022 #20 any idea what started the fault?
