Electric Windows Speed
Jean-Louis Bourdon
Firmware Engineer
Hi
can the cabin electric window speed be adjusted.
they work, but are too imprecise for my taste (compared to my BMW)
for example, there are a few positions i try to achieve and usually takes a few retries:
- ideal gap for deflectors
- lining the glass with the front bottom corner
i think it's more than just speed but also the Full Open/close duration
VCDS?
what do you think?
Speed is not adjustable as far as I know.
Sorry if you've noticed this @Jean-Louis Bourdon .But are you aware there are two ways to control the window. Push the button just a fraction and the window will only travel for as long as you maintain that pressure. Or push the button all the way home and the window will keep travelling until you move the switch in the opposite direction.
thanks, diesldonkey. yes, i know this . tbh i find it drops too fast, and often the limit between fraction and full is too narrow.
I know what you mean, when camping and wanting to have the windows cracked open only as far as the wind deflectors, it takes a very quick stab and sometimes I end up overshooting and going back again to get the position right
