EGR fault codes
Shaw
Egr valve problems
Euro 6 102
Had an oil sensor go on the van the other week which through up a start stop error on the mfd called roadside assist and thay sent the AA out to me, as the AA can read the codes numbers but cant tell what they are related too, iwas then told to book the van in Bradford van centre
Rang bradford van centre the next day and they booked the van in, had to wait a week for them to have a look at it so i rang vw assist and requested a vw assist not the AA
Assist came out to the van and cleared codes and replaced oil sensor egr code still there
the van went into Bradford commercial on monday egr replaced and codes cleared
codes listed below
2 Faults Found:
15560 - EGR Sensor 1
P046C 00 [108] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Mileage: 14922 km
Date: 2015.01.05
Time: 18:54:57
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 49 °C
Intake air temperature: 12 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 13.296 V
Unlearning counter according OBD: 40
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: -0.17 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 50.03 %
Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.504 V
23871 - EGR System
P0401 00 [096] - Insufficient Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 15333 km
Date: 2015.01.12
Time: 06:24:49
Engine speed: 2015.00 /min
Normed load value: 26.3 %
Vehicle speed: 13 km/h
Coolant temperature: 79 °C
Intake air temperature: 6 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.875 V
Unlearning counter according OBD: 38
EGR travel diagnosis: strongly increased NOx emission: 0.00 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 55.57 %
EGR travel diagnosis: marginally increased NOx emission: -23.70 kg/h
Mass airflow sensor 1 bank 1 airflow: raw value: 497.3 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 70.21 %
Charge press. ctrl deviation after throttle valve bank 1-Pressure_16_signed_10_mbar: -7.9 mbar
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 4.316 counts
Readiness: N/A
Just thought i would do a scan this morning to see if everythings ok and
Address 01: Engine Labels: None
Control Module Part Number: 04L 906 056 GN HW: 04L 907 445
Component and/or Version: R4 2.0l TDI H02 2518
Software Coding: 00114014432401090000
Work Shop Code: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056GN 002005 (VN75)
ROD: EV_ECM20TDI03004L906056A.rod
VCID: 7F0D699AE63C56BAD9-802B
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 16659 km
Date: 2015.01.30
Time: 12:43:01
Coolant temperature: 40 °C
Intake air temperature: 15 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.679 V
Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: -1.11 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 50.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.501 V
Will be calling the dealers tomorrow
will let you know how i get on
The date that was recorded was nearly a year ago, are you sure it cleared? Go into the module itself with VCDS and clear the fault codes again.
actually the codes are before the the van was built but the millage is correct will see what the van centers got to say tomorrow
cheers Howard
Van centres keeping it for a day or so to run some test on it
no one can understand why the error codes are not showing up on the MFD butt show up on the code reader
Not feeling much love for this van at the moment
Anyway they given me a 140 to play with, totally different van to drive
Well got the van Back new egr valve fitted hopefully it should be ok for a few year just checked for error codes and nothing showing :thumbsup:
Got to say the 150 van was a much better drive than my 105 think i will be getting a map when warranty runs out
Fingers crossed for you! If anything else comes up, make sure it doesn't need a software update - it took our dealer 11 WEEKS to realise our T5.1 180 needed one to go with the three EGR valve replacements.
Is the 102 five speed? I think the 6th gear of the 150 and 204 helps a lot. A bit hard to remap in a sixth gear though.
@Shaw many thanks for the update, any reasons given for the incorrect date? :thumbsdown: Here's hoping you have a smooth ride of it from now on ;):thumbsup:
Aha, the value of a VCDS shown to enable a visit to the dealer and workshop by an informed and intelligent customer who has, therefore, a dealer bluff potential of zero. I hope that the fault is cured once and for all, but I expect regular VCDS checks will now be conducted. Fingers crossed and good fortune.
on the date issue they said they havnt a clue why this is happening and they couldnt tell me why it hasnt shown up on the MFD, but there will probably a software update in the near future we will see??
just thought i would put an update to this egr problem
after the new valve was fitted my mpg went from 33.12 mpg to 42.36 so i am happy with that same driving style same route
just had the van in today for a software update for the egr valve so i will have to see what happens from now on
@Shaw many thanks for the update :thumbsup:, please let us know how you get on with the software update. Its worth noting the difference on mpg, as some are having difficulties matching others mpg, and although I know everyone's driving styles are different:whistle:, the EGR/software is worth questioning with the dealer to make sure the vehicle is up to date.:thumbsdown::thumbsup:
Phew; I hope that's it for you. Fingers crossed.
